1 - 4 of 4 Posts
Can I remove the screw-on cap and change the oil filter without loosing the oil?
Weird question, I know. I think I can but would like confirmation from one whose done it please.
Thanks!
Most of the oil drains down, you may lose a couple of ounces but that’s about it. So you could in theory swap a filter and not change the oil but I wouldn’t see why you would do the hardest part and not put in fresh oil lol.
Thanks Monte Carlo. I've done so many oil changes I guess I went "automatic" mode in changing the oil last weekend. I remember wrestling with the dang socket extensions and got the cap off, but then I woke at 3 am a few days later going "Did I actually put in the filter?" I checked the maintenance logs where I paste the box labels and NO oil filter box label. So, convinced I was having a stroke, I wrote since I lost all confidence I can ever do an oil change again.
Thanks for the reassurance. I did check and yes, there was a filter but chucked it anyway and dropped in a Wix and pasted the label into the maintenance logs. Sleep good tonight! ;)
Reactions: IDoMy0wnRacing
1 - 4 of 4 Posts
