1 - 20 of 32 Posts
thanks for the share key! unfortunately its the typical modern sea of plastic.... I do find it interesting that the 2.4L Tigershark has been branded Multiair...
Yea its not the most exciting under the hood look that I've ever seen. It would be cool if there was some type of easter egg under the hood, but I don't think that is happening here.
Do you think that putting a different engine under the hood wouldlook any better or would it just look like black plastic still?
What is it with all the plastics under the hood. Can't even see the real engine cover anymore these days.
That is a good question i am wondering now if there also a platic panel surrounding the oil filter and hidden.
Why do you care where the oil filter is? I guess I'm just not the most technical person when it comes to cars. I've never really paid much attention to an oil filter in my cars.
B/c it's a regular maintenance item. Changing your oil and filter can be PITA if the oil filter is not easily accessible. This one does not look that bad.
I just hope they have it covered up with some nice plastic engine covers so that it will be easy to keep clean, hate having to be super cautious about cleaning an engine bay with so many things exposed that if water gets into it can damage them.
I do all my own oil changes in all my vehicles. I get tired of oil dripping all over the garage floor because they don't clean the stuff they spill when they change it. Also some don't change the harder to remove filters because people like you wouldn't know the difference anyway. I suppose you don't rotate your own tires, if not find a friend with a torque wrench and check them after you have it done. The last time I let a Jeep dealer do it because I had a coupon, I found 1 - 2 lugnuts per wheel loose.;)
This engine looks similar in layout to the 2.4 in the Patriot which is very easy to access the oil filter and a breeze to change the oil in.
I'd recommend poking around the KL Cherokee forums and seeing how those guys fare with self changing. The biggest difference is going to be that you cant get the 2.4 Tigershark on the Trailhawk so theres no skid plate issues, but I fear the Renegade TH may be a bit of a PITA.
"The biggest difference is going to be that you cant get the 2.4 Tigershark on the Trailhawk so theres no skid plate issues, but I fear the Renegade TH may be a bit of a PITA. "
The skid plates like those on the Patriot should have a hole in them below the filter just big enough for a hand with a filter in it to fit through. The Patriot has a plastic cover below the engine which is almost identical insize and shape to the front skid plate. ishopped for skid plates for mine and they had it so hopefully they took that que for the Renegade
so if the skid plates are like the patriot isnt that a good thing? since you dont have to remove them
there is a hole already in it for removing the filter correct?
I know a bit different but, some Darts come with an aero treatment. Basically, plastic covering the undercarriage to help reduce wind drag and they have a hinged door for oil filter access. I see Jeep doing the same for there underarmor.
Scott
1 - 20 of 32 Posts
