1 - 15 of 15 Posts
Just had my 2.0 Renegade 4x4 Limited re-mapped today at Yorkshire Remaps in Leeds and it is amazing.
Feels like a different much bigger engine has been transplanted, would definitely recommend.
Sent from my Pixel using Tapatalk
What was the factory BHP?
Haven't had it on a dyno yet, but it was 140bhp original and new map is meant to be 185bhp.
In gear acceleration is amazing and fuel consumption is improved.
Cool. ~180 sounds about the right ballpark to aim for with this engine/car combo without uprating
anything else.
To be honest I'm pretty happy with 140 for the moment but can imagine 180 being on the cards
in the next 8-10 months.
Will probably mean a trip to the UK as I don't trust 'em to do it over here.
anything else.
It involved removing the ECU, but definitely worth it.
Got 48mpg the other day on a 300mile round trip on motorway, managed to drop the average down to 41mpg with a spirited 20mile trip on some nice country roads.
Hey @Kitsamus, are you still running with the re-mapped chip?? have you put in the dyno?
mine is a 2.0 turbo diesel also, but 170hp factory.. please give us your thoughts on how it's been so far.
Thank you!
Thank you!
I no longer have the renegade due to changing jobs.
Never had it on a dyno, but I loved the extra power.
I've been following an Aussie YouTube channel for a few months, just because the guy is nicely outspoken both in criticising the car manufacturers and some of the myths about, for example, HHO generators. I don't generally bother with his specific car reviews as I'm not in the market and the models are often different from ours.
He recently did this rant on chipping/remapping that you might find interesting or amusing.
https://youtu.be/U9tvln5JUW4
Reactions: Nev
Aussie guy has a point and gives good advice.
I've had an ECU remap on a previous car from a well know tuner.
No MASSIVE power increases. Just improved driveability. (Normally aspirated 2.2 petrol.)
And fixing a terrible flatspot left by FCA out-of-the-box.
Concerning this power unit, my understanding is that the 2.0Mjet in 140BHP form
is part-for-part identical with the 170BHPer.
So I wouldn't balk at getting the 140BHP engine remapped upto 160-180 per se.
However I wouldn't do it in the first 2 years of warranty and as there is no 170HP manual
offered I'd look into the clutch before doing it. (I'd assume the auto boxes are also
identical between 140 & 170 models.)
The one thing that puts me off is that on this ECU there's no loading of remaps
via the OBD. Putting a box on it is out of the question for me and ECU removal/opening
I'll probably pass on.
As a note Alfa never sussed I had a 3rd party map on the 2.2 and in fact the buggers
overwrote it without knowing. Twice. (Luckily my map supplier reloaded it for me. But I did have to drive up to London. ;))
Be carefull,
Re-mapping, re-chiping the 140HP engine to 180HP will reduce the lifetime and reliability of several components.
Note that the Trailhawk engine (170HP from factory) has a different turbo, different injectors, different bearing, sealings, etc.
If you just re-chip/re-map a 140HP engine, the turbo will work with higher presures (that it was not designed for), higher temperatures (that it was not designed for), and the engine sealings, crankshaft bearings will by sbmitter to higher strees and pressures (that they were not designed for).
Also the manual transmission/clutch will suffer accelerated wear.
Finally.... The better fuel economy is achieved adjusting the air to fuel ratio.... that results in higher pollution, well over the EURO 6 emissions.
It works, but the engine lifetime/lifespan is reduced and pollution emissions increase.
I recommend to study very well the subject before re-maping/re-chiping, so that you can make a fully informed and conscient decission..
Best regards,
Bruno
Trailhawk (2.0MJET 170HP)
Thanks for the insights Bruno.
Hi guys, now we own the Trailhawk outright and it's out of warranty I've been thinking of a remap primarily for improvements in consumption.
Further to this thread has anyone else done this, or can recommend reputable tuners?
I'm more than happy with the 170bhp and torque this engine puts out.
Sent from my SM-G935F using Tapatalk
Dragging up this old thread, but I just had my 2.0 Limited Mapped from 140 to 185.
Absolute beast of a diffence and fuel consumption is improved. Ace Remaps in Shrewsbury sorted mine out
1 - 15 of 15 Posts
