Hi,
I see the Apollo comes with 20" wheels as standard and a tyre of 235/45r20. Standard wheels seem all to be ET40.
What I'd like to know is if anyone has fitted wheels 'wider' than 7" which is the standard width and will an ET35 work?
Usually there is a lot of tolerance in the wheel width to the outside arch.
I'm thinking of fitting Niche Targa's, 20x8.5r20 ET35 with 245/40r20 tyres.
Anyone else gone this wide, do they fit OK?
willtheyfit.com gives this compared to the stock 18" on the "Limited" so the inside looks fine, it's more the poke I'm worried about as it's an inch wider.
http://www.willtheyfit.com/index.ph...ameter2=20&wheelwidth2=8.5&offset2=35#content
