1 - 13 of 13 Posts
Hi, I'm new to this forum. I've been having problems with my 2015 Renegade Sport battery.
The battery went dead and few times got a boost then service transmission light came on and I couldn't get it out of park.
Got it towed to dealership and they called and said dead battery. Dealership reset everything and I picked my Jeep up. Now it happened again,. So, my question is do I need to buy a new battery?
These Jeeps are famous for going bat-crap crazy if you jump start them from another vehicle; a BIG no-no. As you well know...now. A battery jump pack is the only way to go. You'd think that Jeep would put a big decal/sticker warning to NOT jump start from another vehicle, but no. Instead you got an Italian spider greeting you on your gas filler neck...
In your Owners Manual there is a section that tells you how to override the the transmission lockout, look it up, but basically you pop the bezel off around your shifter and use a screwdriver (or your emergency key) to release the lock. If I were you, I'd release it then drive straight to the dealer. They may have to re-flash your computer.
All this because your battery died. Ain't it grand ?
Discussion Starter #6
Yeah, dealer will charge 200$ to do that like they did 2 weeks ago for same issue.
welcomegroup
and enjoy the forum!
That is why a warrenntee is needed on any thing over 3 years old.
Discussion Starter #8
Not working what's emergency key.
It sounds like the dealer needs to flash/update a module..I recall seeing the stuck in park issue on 2015 being a module flash
Discussion Starter #12
Hi got my renegade towed back to o my house from dealership.... dealership advised gear shifter assembly needed to be replaced and cost is 1500$
1 - 13 of 13 Posts
