1 - 6 of 6 Posts
Hi - I have a 2015 Jeep Renegade Latitude, it's been really good - but during the last year, the TPMS system has been mostly OUT - not working... sometimes it works for a week or two, but then it will go out again for a month or two. So I took it to my dealer and had them check it - I have the LifeTime MaxCare Mopar warranty, so it should be covered - right? OK.
So they needed to install a new "RF HUB" to communicate with the TPMS sensors in the wheels - seems to have worked, but the RF HUB also communicates with the KEYFOBs - so they were having issues programming the original keyfobs into the new RF HUB. I have owned this vehicle for 5.5-years and NEVER had a problem with the keyfobs - I have replaced the batteries in the fobs, but they always worked fine.
Of course the dealer wanted to charge me $285 for a new keyfob - I told him I had the MaxCare warranty - and that does cover keyfob replacements, but only 3 or a max of $600 benefit for the first 7 years of the warranty - after that - no warranty on the fobs.
My argument: MY MaxCare warranty is MINE - I paid for it, and I do not want my dealer benefitting from it. If I lose or break a keyfob, then I would expect my warranty to cover that, but I do not like that the dealer is expecting me to simply let them use my warranty.
I have already talked to the service manager and logged a complaint with Mopar Customer Care.
Does anyone have any other insight?
I am an electrical engineer and computer programmer. I understand the security aspect of programming keyfobs, etc, but I think this is something that should be doable - am I wrong? I've seen videos of programming keyfobs into systems and it doesn't look very difficult, just time-consuming and you need the right hardware and software.
Has anyone else ran across this situation before?
Thank you for any feedback!
PAT.
There are issues with programming the lock system to accept "used" keys. So if they've replaced part of the system, I guess it won't now accept the original keys as it sees them as having been coded to another system?
Discussion Starter #3
This seems like a HUGE design flaw - specifically in my case... why am I expected to absorb the cost of new KEYFOBs or to have my warranty cover it - I did not break them, and I was not warned this might happen. There should be a way to send them back to MOPAR and replaced at the manufacturer's cost for not being able to re-program. Either way, BEWARE Mopar owners... if this continues, I smell a class-action lawsuit. You shouldn't be forced to buy something just to make something else work because "that's the way they designed it".
Agreed. Cost should be on FCA. (Or Stellantis as they are now known.)
PAT.
Hello PatPicciano,
Sorry to hear that! I would encourage you to message our team privately so we can look into this matter further.
Hannah
Jeep Cares
1 - 6 of 6 Posts
