When you got the rear metal bumper off, what is TH left tow hook bolted into? Is it just into the metal bumper itself? Looks like 4 bolts/nuts holding the metal bumper to body and then some extensions that slide into frame rails and get bolted or is there more that I can't see?
On the factory non tow hitch metal TH bar, what does the screw in eye hook go to? Does it extend into frame rails or just into the metal bumper also? I'm checking as I want to use it conjuction with the factory rear hook in case I need to get pulled out/unstuck from behind. I'll be using something like this
http://www.masterpull.com/3-4-x-10-super-yanker-kinetic-recovery-bridle-19-000-lbs/ liek manual says to use both front hooks if needed.
Hopefully in summer I can get the Father-in-law to authorize the hitch itself but would probably still want something on right side to spread the load if getting pulled. Hitch would probably have a cargo basket in it then.
