21 - 31 of 31 Posts
Exactly why I do ALL my own maintenance. :(
My favorite was the Costco guy who I asked to use a torque wrench a while back. He used the impact gun first, then went around with the torque wrench but they all instantly went "click-click-click" without moving, and he was happy. I pointed out that the only thing he measured is that the lugs are AT LEAST the recommended torque setting, but possibly much much higher, and that's not how you use a torque wrench. He just said that's normal procedure and walked away dismissively. Sure enough, I couldn't get them off the truck myself even using a long breaker bar as they were probably 200ftlbs and had to get help.
1st Tire Rotation "Walmart" Screwed Up (1) Ea. Lug Bolt on Tire Rotation Removing the 1st Bolt on 1st Tire. I Told Them to STOP! & Took Vehicle to Tire America For Tire Rotation (Had to "Buy" New Lug Bolt) Prior to Going There. Tire America Performed 2nd Scheduled Tire Rotation. Went For 3rd Scheduled Tire Rotation @ a Shop That "Only" Does Tires & Technician Said, "I May Be Able to Get These Lug Bolts Off. But, I Can't Guarantee I Can Get Them "Torqued" to Specs.
Here's the Problem. The Wheel Lug Bolts Are "Not" Solid Bolts. They Have a "Chrome" Cosmetic Cover Swedged Over Them****IF Any One Uses Anything Other Than a (6) Point Socket on These (6) Point Covers it Will Distort the Chrome Cover Also, IF They Lay on Them Hard Using an Impact Gun Even (if) They Are Using the Appropriate (6) Point Socket & Tighten Them Up Hard Using an Impact Gun. It "Will" Distort These Chrome Covers**** ( I Needed (9) @ $6.15 ea. = $55.35) Jeep Dealership Only Had (3) in Stock) & Vehicle Was Stuck Up on Rack. You Will Likely Never Know Because Distortion is "Hidden" Down in Valley of Wheel Recess. The Technician Had to Grind/Cut Off the Chrome Covers to Get Lug Bolts on & Use "Smaller" Socket to Get Me on My Way. Bad Part is (if) You Have Flat Tire on Highway. "You" May Never Ever Get Your Lug Bolt(s) Off & Have to Have a TOW
I Called Jeep Dealership & Ask (if) There Were Any TSB's Cust. Bulletins or Recall on These & They Said "No" *Beware Makes Sure Technicians "Only" Use (6) Point Socket & Uses "Only" HAND TOOLS to Remove/Replace "NO" Impact Guns (See Attached Photo)
go to madness auto and buy a set without the chrome cap. the chrome cap expands and you have to hammer the socket onto the lug nut to remove. just a bad design, change before you get stuck somewhere and your lug wrench will not fit on the lugs
old problem many threads on this, go to madness motor and buy unwrapped lug bolts, you will be glad you did, because the chrome wrapped bolts will continue to give you problems
Here is a link these are very similar to what I bought. If you buy the silver zinc coated ones like the ones I bought they are $36 on this website. Do yourself a favor and switch them all out ASAP. My break pad change literally took me 4 days of hassle because some not so bright lube tech had a impact and cranked mine on too tight! Pic is of lug sans cap (oh fun surprise without the cap it’s a half size socket you need to remove it). If worried about buying from this website buy from NAPA they carry them but a set will run about $70 + shipping. They are m12 x 1.25 . My Jeep dealer quoted me $300 to replace all of them with the same factory capped lugs. Don’t get me wrong I love my Jeep this is just a part that needs to be replaced!
Jeep Renegade Lug Bolt Set by Farad - Set of 20 - M12x1.25 - 60° Cone Seat - Black
Is the photo shown the bolt you bought from NAPA or from Renegade Ready? Thank you, Chelzy
W E L C O M E ! ! !
... to the forum.
Do a search on Amazon for LUG BOLT 12x1.25 Wheel Lug Shank 28 mm.
This way you can chose the color and security that best suites your needs.
For example: 20 Pc 12x1.25 Black Spline Tuner Conical Lug Bolt Replacement - 28 MM Factory Length
Keep in mind, you will need 20 of them. If you have wheel spacers, you will need to add the spacer width, in millimeters to the length of the lug bolt.
for example: 28 mm is factory length. If you have 1 inch spacers you will need 50mm lug bolts (I used 48mm lug bolts for my 1 inch spacers and they fit perfectly).
If you go too long, the lug bolts will hit the spindle, too short, they won't hold enough and/or strip out.
2019 Renegade Trailhawk
I picked up these lug bolts to replace the originals on my Renegade. Whoever owned it originally had overtightened and damaged the caps on one wheel. The replacements are not identical in size, but they match where it counts. The polished head is indistinguishable from the original once installed. The first image shows a replacement (top) and original (bottom).
Audio equipment Household hardware Cylinder Auto part Nickel
Material property Automotive design Font Electric blue Plastic
Tire Wheel Automotive tire Hubcap Alloy wheel
21 - 31 of 31 Posts
