1 - 8 of 8 Posts
I purchased a Jeep Renegade 2017 DesertHawk a few months ago and I’m looking for any advice I can get about possible towing options from this group.
It’s a 2.4 L Tigershark engine and I’m aware of the 2000 lb towing capacity. Could anyone recommend a compatible cargo trailer? I’m moving to New Brunswick and wanting a cargo to help me with the move.
Has anyone had any success with this? Failures?
Thanks!
Thanks man! That’s what I need to hear! I’m wanting to get a trailer to help with a move from Toronto, Ontario to Moncton, New Brunswick.
I could rent a truck but ideally if I could just load up and drive would make it easier all round for me.
My engine is the 2.4 litre Tigershark (2017 Jeep Renegade DesertHawk)
Love this Jeep so far and if it could prove itself I’d love it even more! ?
Search for my posts on trailering. There are a few and your car will pull a lot better than you think it will dependant on engine size. Mine is Renny 2.0l 4x4
· Premium Member
I proved by accident that my Jeep can pull almost double the recommended weight.
However I fully understand that there is a safety factor of usually around 50% or a little higher dependant on circumstances on which the maximum gross weight is defined. Please do not exceed that limit knowingly as the negative outcomes could have far reaching circumstances beyond your control. Death of you and or others as a worst case scenario. There go I but for the grace of God.
What distance are you expected to cover and what weight of domestic items are you moving? 2000lb is around 900kg or just short of 1 metric tonne. That needs in the UK a trailer with a brake. US Laws I have no idea of the equivalent.
750kg overall weight of trailer and load in the UK requires a braked trailer so if your load is anymore than that may I suggest that a truck is a better option?
Should it be be that you have a braked trailer then at the least carry with you a spare "Hub" with a fully fitted wheel bearing and a spare wheel/tyre, just in case of emergency purposes and that you stop and check your wheel nuts every 150 miles.
Regular checks should be carried out if using "Cargo straps" to cross secure your load. Accidents do happen but you can minimise them if using a trailer.
The choice is yours. (y)(y)(y)
Thanks for the Mindful tips!
Really appreciate it! I’ve not done this before, ever!
I’ll keep all that in mind when looking at trailers!
The one I’m looking at is a 6x10 Atlas trailer single axle with no brakes and it weighs 1000 lbs.
1 - 8 of 8 Posts
