41 - 60 of 78 Posts
Anyone else experiencing jerking/lunging of the 2017 Jeep Renegade during acceleration up hill, down hill or any other times?
[/QUOTE
yes - i recently purchased a 2017 Jeep Renegade Latitude 4x4 from CarSense and i’m having the same issue. at first i thought it was just my imagination because i’m already a nervous driver to begin with, however, i’ve had other people drive it to see and it’s definite that there is an actual issue at hand. mine will suddenly jolt going both up and down hills at about 25 mph. the weird thing is it doesn’t happen all the time and it’s really hard to replicate when trying to show someone. i’ve had this car for about a month now and i’ve noticed those jolts about 4 times. either way, i’m not messing around with any problems and made an appt for this saturday to get it looked at. hoping they’re able to fix it but am going to show them this forum so they can see it’s not just me.
Jolting at 25mph immediately conjured up an image of an inexperienced driver whom has selected a gear that is too high for the speed they are doing.
I know my Jeep 4x4 Longitude (manual, diesel) can do 25mph in 4th gear extremely comfortably. 5th gear and it will get a little tempremental and start to ever so slightly judder but if I merely accelerate a little to 30mph I can alleviate the juddering and at 35mph to 40mph I can drop into 6th gear.
Now this is important I have my Jeep chipped however any modern car, never mind a Jeep should be able to sit at 30mph in 4th gear without jolting.
Are you therefore driving in the appropriate gear at the appropriate moment depending upon the terrain you on whilst taking into consideration the incline or decline that you are traversing?
thanks for getting back to me! that’s really interesting, i didn’t even think to add that mine is an automatic - so i’m guessing i’m not able to switch gears on my own then? i apologize for my lack of knowledge, this is the first car i’ve ever purchased. i was also thinking that maybe it’s just not recognizing the change of gear quick enough to register. i just had my mom drive it to see if she felt it and she drove a lot quicker than me up and down the hills by us with a lot of random braking and she didn’t feel it at all... so strange. i’ll be overthinking until this appointment on saturday haha.
i apologize for my lack of knowledge as this is the first car i’ve ever purchased.
So glad am I that you will be thinking!!!. With such an insult to me, you can go and ? Ask others
Motor Mounts. Have your motor mounts checked. I sounds as if you have at least one of the three motor mounts have failed.
Reactions: dgr401
I have a 2017 w the same problem.To be more exact , at around 25mph when it shifts firm 2nd to 3rd gear, sometimes is jerks/kicks back violently.how often, well I think too often and quite frankly I’m not happy about it, the problem is I tried to explain it to the service adviser at my local dealer many times and I can’t replicate it when I’m there. It only does it whenever it wants, I couldn’t detect a pattern.
I saw an older post about this, but kinda lost track of it and then couldn’t find it any longer.
A good example of when the car would do this kick back/transmission jerking is for example you stop at a stop sign, then accelerate straight and realise there’s another stop sign coming up so about 25 miles an hour you ease off the gas pedal because you need to stop again, I think that’s when the Jeep does it. I really don’t know how to recreate a situation for this to happen but it’s very annoying
1 - 20 of 47 Posts
Next
K
klittle15
Joined Jun 5, 2019
Discussion Starter • #1 Jun 5, 2019
SaveShare
Reply Quote
Like
[IMG alt="Mrsig"]https://www.jeeprenegadeforum.com/d2/avatars/m/16/16641.jpg?1570689210[/IMG]
Mrsig
Joined Jul 5, 2015
#2 Jun 5, 2019
and enjoy the forum!
Our 17 drives great 0 problems.
Show Full Signature
Me 07 JKUSR, CEO of Black Sheep 4x4s org
White Jeep Club Member # 137
To see my mods or Jeep in action go to JKUSR
Wife 2017 Jeep Renegade Trailhawk 4x4 2.4L, 9 speed Auto.
White Jeep Club Member # BU01
SaveShare
Reply Quote
Like
C
Commando
Joined Mar 28, 2018
#3 Jun 6, 2019
My 2015 was doing the same between 1st and 2nd gear. Issue was random but took it in to dealer. It took three days to diagnose and get back to me but following is what they found:
"Scanned for DTC's none present, looked for available software updates and TSB's has TSB 21-003-18 lists his concern as fixable with software, PCM and TCM are both out of date, need to be done at same time 18-19-06-UE 0.2 hr 18-19-05GX 0.2 hr flash programmed PCM and TCM to latest software level per TSB 21-003-18"
This was covered under warranty for which I'm grateful. It does make me wonder though, has anyone had software updates that were not covered under some sort of warranty? I suspect most owners on this forum still have warranty coverage but as these run out what kind of charges can we expect to see in the future should a "fix" require a software update. Mine has 47K on it now and if it needed a software fix with these miles, I'm sure it may again.
As for how it drives now, it does "feel" different . Hard to explain but shifts seem more immediate. Since my problem was so random, I don't know if this fixed it or not; only time will tell. I did notice that on the ride home I take a highway with a 65mph limit. Where my Renegade would usually get to 9th gear, yesterday it never made it out of 8th. There may have been a head wind so will monitor but am certain the shift points have been changed or TCM/PCM is re-learning.
SaveShare
Reply Quote
Like
[IMG alt="JeepCares"]https://www.jeeprenegadeforum.com/d2/avatars/m/12/12226.jpg?1573058240[/IMG]
JeepCares
Joined Apr 23, 2015
#4 Jun 6, 2019
Hello klittle15,
Are you thinking you'd like to get this inspected by your Jeep dealer? Send us a private message if you need any help with this process. Very sorry for any trouble you've encountered as a result of this.
Jasmine
Jeep Social Care Specialist
SaveShare
Reply Quote
Like
A
Adicxxl states it perfectly! My 2017 Jeep Renegade does the exact same thing. Can't make it happen at the dealership and a software update did nothing to help the problem. I can't believe a software update was even sent out. It's really annoying and disappointing! We're actually talking about getting rid if it unless a fix comes along.
Hello and welcome Kakman. sorry Hakman, for me they both mean shite :cry: ie HAX, HAK, KAK just saying. It may just be my regional dialect and if so then sorry before we even start chatting.
My praise though must appreciated as I think you have did a thorough search but may I ask exactly what your request is? The forum members are highly qualified in a variety of Jeep issues. :love:
In what way can the forum assist you today? :unsure:
As an example. I sometimes find my Jeep jerks a little in reverse but only when reversing a fully laden trailer. I thought it was my drop links but what do I know? It was suggested that it may be a worn out tow bar.
Can you see what I mean about how to ask a question? Please do not let my post put you off from replying. I am merely demonstrating how anyone with a little instuction can reply to your topic. The more the merrier (y)
1 - 20 of 47 Posts
Next
K
klittle15
Joined Jun 5, 2019
SaveShare
Reply Quote
Like
Mrsig
Joined Jul 5, 2015
#2 Jun 5, 2019
Show Full Signature
SaveShare
Reply Quote
Like
C
Commando
Joined Mar 28, 2018
#3 Jun 6, 2019
SaveShare
Reply Quote
Like
JeepCares
Joined Apr 23, 2015
#4 Jun 6, 2019
Hello klittle15,
Jasmine
SaveShare
Reply Quote
Like
A
Hi there, we are sorry to hear this! If you would like our additional support while working with your dealer to resolve this, please do not hesitate to reach out to us privately.
Kathryn
JeepCares
Yes I have taken my car in 3 times. To be told they couldn't find anything or the transmission was reset. the last time I took it in i was told no error message showed up . But when it does please bring it back in and then he also said if I could record it on my phone when it happened..really? I have about 3000 miles left on my warranty
I am also having the same issue with my 2017,
My sister and I both purchased automatic 2017 renegades on the same day and started experiencing this lurch from our vehicles around the same time about 2.5 years ago. After a stop we would drive around 25-30 mph, and then feel this huge lurch from the engine. It's so startling, it almost feels like someone comes up from behind and pushes the vehicle. We have had the dealership inspect our cars a few times with no luck. We continue to have the issue intermittently. Hoping to find some good info on this thread! Also, the best steps to take since we have already been to a dealership. What do we say to have them take us seriously?
Hello klittle15,
Jasmine
I am having the same problem with my 2017 renegade . How do you get the Jeep specialist to contact you ?
Do you mean the Jeep Specialist as in the local Dealership or "Jasmine" in the above post @ JeepCares?
The first is a personal phonecall from you to them. The second is to merely await a reply as Jeepcares tend to monitor the forum for their name. If it's the second option then you have did the hard work already by posting a comment. (y)
Recently my 2017 renegade which has 44,000 miles on it, is burning oil at a rapid rate. I am also having this jerking problem (automatic transmission) around 3rd gear and up. I got a text message today about recall W84 which says it's for a powertrain issue and a software update will fix it. On another forum, some people are thinking this is an admission of the oil burn issue. I'm not connecting the two. Calling my dealership this morning, but I'm definitely not happy. I've loved my jeep up until the last month. Don't need to be adding oil all the time, this is ridiculous.
W84 was created to address oil consumption concerns. It is mentioned in the owner letter.
Kaitlin
Jeep Cares
Thanks for tagging us here, @puddlesplasher.
First, we would like to apologize for our lack of involvement within the past months. This was due to technical difficulties and we are deeply sorry for this inconvenience. If anyone is still in need of assistance with a previously shared vehicle symptom, do not hesitate to reach out in private message and we will be more than willing to offer our additional support moving forward.
Kate
Jeep Cares
Yes. I have a 2017 Jeep Renegade Sport 4x4 that does the kickback at exactly 29 MPH. Has 44k miles on it. Does the kickback every so often I think between 2nd and 3rd gear at exactly 29mph every time.
Yes, mine surges/accelerates going up hill. It's also very slow and sluggish at take off now. Took it to the dealership and all they said was that it needed a fuel induction service!
41 - 60 of 78 Posts
