2019 2.4L Renegade latitude leaking oil
3126 Views 4 Replies 5 Participants Last post by  Grandpa Dude
My renegade has just over 26,600 miles on it and is due for an oil change at about 27,000. I got an oil change around 21,000 miles and the guy did not properly put back on the oil filter so I had blow back underneath the entire part of my car and up the tailgate because I travel. I went back and had them redo it and everything seemed fine but now that I am coming up to for another oil change I have noticed the oil filter looks like it is leaking. I do not see anything on or around it that looks like it would have obstructed it or caused it to leak so I’m wondering if the oil filter is a common thing to be leaking for this engine.? I know the 1.3L has issues with the housing. Or do the filters just leak when it’s time to change the oil? The oil level is also half way down on the dipstick but that doesn’t raise too many flags.. I think.
1 - 5 of 5 Posts
if the dealer screwed up the first time, they probably screwed up again, sounds like they are over tightening the filter and screwing up the rubber gasket. i would have someone else do the change and see what happens. rare the filter base goes out of round and that should be from day one
Reactions: 1
and enjoy the forum!
jeff1 beat me to the answer again..
See less See more
Reactions: 1
Ehh :unsure: No.
Your Jeep is not mechanically nor electronicially designed to start dumping oil out the filter when it's time to change. What an environmentally unfriendly car Jeep we would all have.
However if I take your words literally then you are quite correct and that it is indeed time to change the oil with a leaking filter as you could never be quite sure how bad the leak really was or for how long it had been happening. You would be forever taking dip stick readings as opposed to having the reassurance that everthing is OK.
Bite the bullet, pay the price and replace the oil and filter yourself. There are many great posts and pictures of how to do it that are available on this forum or even on You Tube.
Tableware Drinkware Dishware Font Serveware
Please take the time to find an appropriate Thread via the community search engine, and introduce yourself.
:cool:
See less See more
1 - 5 of 5 Posts
