1 - 6 of 6 Posts
Hey all, I took my stock 2020 Trailhawk on the beach for the first time last weekend and it did so well that I decided I didn’t need a lift..... well then I came across Avid’s economy/budget 1.5” lift and for the price and all the reviews I read, I was sold. With the idea to install a lift replanted into my head, I naturally started to look into larger wheels. While looking in the wheel wells for my 20 I noticed how there seemed to not be any pinch welds that would cause issue with a larger set of tires. Like none at all. Is this something they updated with the facelift models or am I missing something?
i also noticed that the stock tires sit really close to the strut perch. If I get the Avid lift will that clearance still be an issue with larger tires? Any help would be appreciated!
Hey there,
I have a new 2020 Renegade Trailhawk as well. I recently added BFG 225 65/R17 tire and Rugged Ridge 1.25” Spacers. I noticed I have slight rubbing when I turn full right/left. I’ve also noticed that the 2020 models now have a metal plate installed in front of where the pinch seam weld would be and on top of that is a new acoustic fabric attached to the wheel liner. This limits the space behind the wheel at full turn. Most with older model Renegades don’t have any rubbing issues with a 225 65/R17. But that doesn’t seem to be the case on 2020 models. Not from my experience once adding spacers. I haven’t fully taken my liner off but I was pretty sure there was still a pinch seem weld behind that metal plate. Can you confirm your is this way. Hope this help and didn’t confuse the issue. Take care!
Discussion Starter #3
Hey there,
I will be sure to check that out when I get home.
So if I’m unwilling to go the Spacer route, I should get a lift? I had plans to go for a 225/65/17 as well but would rather stay away from spacers given the conflicted opinions on them. I’m new to all of this so I’m not quite sure which way would be better.
Hey there,
I have a new 2020 Renegade Trailhawk as well. I recently added BFG 225 65/R17 tire and Rugged Ridge 1.25” Spacers...
If you were to change to front spacers to 1 inch (so that you have 1 inch in the front and 1.25 in the rear) the rubbing will go away.
Hey all,
if you go larger then 28.5 inch tire, you will need a 1 inch spacer to clear the spring perch (i.e. 225/65R17 no spacer required; 235/65R17 requires a spacer).
1 - 6 of 6 Posts
