Yes, you will be fine with that setup. Anything larger then a 1 inch spacer will cause the tires to rub a little bit when turning (at about 3/4 turn) with 225/65R17.Will 225/65/17 tires fit without any rubbing on a stock 2015 Latitude with 1" spacers?
Let me know I just bought a 2020 Jeep Renegade latitude with 17x 7 rims. I was looking at the 225/65R17 tires as well.I have a 2017 latitude 4x4. I am having my Pirelli All terrain plus 225/65/R17 installed on Friday. I'm not using any spacers. I'll let you know how it goes. From what I read from all the guys on the forums, they should be fine so that is why I am going for it.
Welcome to the forum. There is a lot of great info on this forum. You will not have any problem with the 225/65/17 on your Latitude. Enjoy your new Latitude.Let me know I just bought a 2020 Jeep Renegade latitude with 17x 7 rims. I was looking at the 225/65R17 tires as well.
Thanks! Guys!with
I had the Pirelli All Terrain plus 225/65R17 tires installed. I think they look and ride great. Also, they raise the clearance from the 67K miles that were on the original OEM tires.You should be good, we like pictures, please post some pictures of your Renegade after you have the new tires installed.
Do you have any pictures of your renegade with the 1” spacers ? I would like to know how they look ? Cuz I wanna do the same thing to my renegade get the same tire size 225/65/17 with 1” spacersYes, you will be fine with that setup. Anything larger then a 1 inch spacer will cause the tires to rub a little bit when turning (at about 3/4 turn) with 225/65R17.
Whats a good brand of 1” spacers ? 🤔Yes, you will be fine with that setup. Anything larger then a 1 inch spacer will cause the tires to rub a little bit when turning (at about 3/4 turn) with 225/65R17.
Wheels and TiresDo you have any pictures of your renegade with the 1” spacers ? I would like to know how they look ? Cuz I wanna do the same thing to my renegade get the same tire size 225/65/17 with 1” spacers
No, the 225/65R17's should fit without modifications.I never thought about a different size in spacers for the rear. But thank you for that small detail it helps a lotalso another question after adding those tire size “ 225/65/17 for off roading, would I need to do any other work on the suspension, on the springs or bushings or shocks.?? So I don’t mess up my Jeep cuz they have to be very well done. & it’s my first Jeep I always owned cars & I don’t wanna have rumbling issues 😅 or anything like that. I wanna take good care of it
