I'm a lifelong Mopar guy (50+ years) who only bought this reskinned Fiat because there wasn't much else in the way of manual trans small 4-bys. I came out of a stone-ax reliable 2000 Cherokee that was a faithful winter beater (even though also not really a Mopar....)
Mine's a Latitude, Abarth engine, cold weather package, 6.5" UConnect/Nav.
3000 miles on the clock. Some early impressions now backed up by reasonable seat time. First, the good:
> Quicker than I expected.
> Trans shifts flawlessly and the gear ratios are BRILLIANT.
> Styling draws lots of looks (mine is Orange), also a chick magnet
> Overall I'm relatively satisfied.
Now the so-so...
> Electric power steering is pretty dead on-center, wanders some
> Gas mileage as advertised (on 91), really should do better
> Seats look like they should be comfortable, but aren't great. My '99 Neon ACR, and the old Cherokee, were much better for long trips. Can't put my finger on it, but lower backaches are a given after 30+ mins.
And the negatives, in order of annoyance:
> The hill-holder is terrible. Way too aggressive, I stalled it 100 times before finally killing it off (and I've driven manuals since 1962). Tied into this is the USELESS electric parking brake. A fix: A simple button somewhere to active the hill-holder only when you really need it (very steep hill, traffic up your butt).
> Worse -- unforgivable: When it stalls, you can't just crank it up and go -- unlike any real Mopar. You must turn the key OFF, reboot, then crank. Try that in the middle of an intersection.
> NAV is horrendous. What more to say? I was told it's be the same as my kid's '14 Viper just a smaller screen. It isn't. I went back to using the cellphone and Google maps. Could saved $1K had I known. This really irks me. Really.
> Whomever designed the oil dipstick and tube needs a lesson in ergonomics and usability. The tube is buried in a dark hole of the plastic trim shroud. Make the tube 1" longer and the problem goes away. Also the book calls the dipstick handle yellow, it is black.
And one straightforward comment:
Except downhill or coasting, the thing is virtually always making boost. I've seen as high as 20+ PSI, 2-4 PSI at 65-70MPH cruise.
Rick Ehrenberg
Now the so-so...
Rick Ehrenberg
