1 - 4 of 4 Posts
Should probably be something like this.
Red power +
Black power -
Blue goes to reverse light power + (probably to turn on the camera)
AV1 to DVD player
AV2 to Camera line feed
Red power +
Black power -
AV1 to DVD player
So red and blue can go to Red reversing light wire? All 3 together?
sometimes the blue and red can be wired together like that but cant promise that it will work that way. If the monitor has some kind of memory then you have to wire the red into something with constant power or the memory will be wiped every time you leave Reverse gear.
Black can be grounded at existing bolts in contact with the metal chassi dont need to wire it all the way to the rear.
1 - 4 of 4 Posts
