Can't load image properly and can't delete thread. I thought I had it figured out but I guess not.
OK,
go to
www.photobucket.com and create an account, its free. Then upload your photo from your computer onto photobucket using their upload feature (click upload button, search your computer for the file and double click on it). The reason for this is that you can only post pictures to this forum that are already on the internet somewhere, so you need photobucket for that.
Next go in your photobucket account click "library" to find the picture you want to show on this thread - click on it. Then, look to the right of the picture - there are 4 options under where it says "Share this photo" - click the bottom one (labeled as "IMG") it should automatically copy to your digital clipboard and it will say "copied" once you click on it.
Next come to this forum in this thread and type up a new post, and under the text that you type, when you are done typing about the description of the photo, hold down the CTRL button and while you are holding it down, tap the V button on your keyboard so that they are being pressed at the same time (or right click and select "paste") or Command+V if you are a Mac user. This will paste the image address into your post - so you will see a strange looking code show up, and that is what you want. Click preview post and your picture should appear there instead of the code. Then click Submit to permanently post it to the forum.
Hope this helps.
