1 - 4 of 4 Posts
I had trouble with oil consumption for quite some time, and spent quiet a bit of time at the local dealer's going round and round through the process of verifying excessive oll consumption. I even brought it back for the last recall where they remapped the engine controls to supposedly minimise oil consumption. There was a lot of miscommunication regarding whether or not the car was normal and what the remedy was going to be. Trouble started with just over 20k on the odometer when after i brought the car in and said there was something very wrong because of how it acted (no codes of course) I was told there was nothing they could do... then the next day it threw a code for a bad cat convertor. It was replaced but the car never really ran right and all alng had been using a quart every 1-1.5 k miles. I kept on bringing it back, and then got FCA involved. Finally I was told to bring it in and they were going to give me a loaner. Well it is nearly two months later, and I picked the car up today with a new engine. So far as I can tell the swap came out perfectly. It hasn't ever run this quietly; seems like the new engines have a quieter valvetrain. The gas mileage had dropped quite a bit as the engine got older but it seems to be back to where it was originally.
Doing a swap like this is a big job; the whole powertrain has to come out of the car, which means the suspension and drive shafts get partially disassembled, the A/C gets pumped down and opened. The tech did what looks like a great job: I cannot find any faults whatsoever. A/C runs great, transmission shifts perfectly all fluids are up to the correct level.
This is the happiest I have been with the car since I bought it. I took it home and gave it a good cleaning and wax. I will keep a close eye on the dipstick but have been hearing the new engines have much less trouble with this problem so hopefully it will be right going forward.
2396351148
Good to hear Jeep fixed your little Jeep better than new. Enjoy it.
Reactions: greyghost
Just an update - i just passed 1k miles and the dipstick says full. It seems to be loosening up a little now as I got 36 mpg on a drive to the coast (NW Oregon) going over a pretty good mountain pass. Runs better than new. I finally found one defect in the job; the windshield washer reservoir was not reinstalled correctly. I will take it to the dealer next weekend and get it done. All else is well!
1 - 4 of 4 Posts
