1 - 5 of 5 Posts
Hi folks
I own a 2.8 renegade 2005 and have a list of codes:
Code 21: Front Right hand sensor open
Code 22: No signal right hand front sensor
Code 23: Intermittent signal right front sensor
body ST: LE mismatch
Code 82: Number of ring teeth out of range
Code 48: Left front Dump solenoid shorted
Code 44: Right front Dump solenoid Shorted
Code 67: Pump motor circuit open
Code 81: Brake switch circuit
Code 91: Right hand front sensor shorted
I have replaced FR sensor, swapped wheel bearings to see if codes move from left to right and changed the ABS pump but still get the same codes. I'm now thinking of wiring issues but I'm not an auto electrician. Any advice would be appreciated. Right hand drive based in the UK
JEEP CHEROKEE RENEGADE CRD
2.8 D
OY05 NBK
VIN No:1J4GMC8535W609991
Engine code: ENR​
Update on ABS issue.
Checked all the sensor OHMS and couldn't believe no reading on LEFT hand sensor (New 18 months ago). Replaced LEFT hand sensor and no more ABS light. I was always under the impression that left and right are from sitting in driver's seat not facing the vehicle from the front :(. If you need any ABS pumps etc tested in UK look up ECU testing. Great team and only charge return postage if they can't find an issue.
1 - 5 of 5 Posts
