1 - 4 of 4 Posts
I have 2015 Jeep Renegade Trailhawk with:
1. Uconnect 3 with 5" Display (OEM Radio)
2. 9 Amplified Speakers w/Subwoofer
I am trying to upgrade the OEM Radio (Uconnect 3 with 5" Display or Uconnect 5) with Universal 2-Din, 10: Touch Screen DSP Android 8.0 System (Fancy name). The unit is on androidautoshop dot com This unit is almost the same as XTRONS TE103AP.
I am using Connects2 Info-adapted CTUJP01 to interface with the Uconnect system, to retain the SWC, and display vehicle information system.
I was able to install the aftermarket radio with the CTUJP01 info-adapter and lost two (2) functions, the backup camera, and the OEM Amplifier or Audio System (9 Speaker=8 Speakers + Subwoofer).
3- The Backup camera: the backup camera function on the CTUJP01 is designed for aftermarket backup camera, not the OEM Camera. I was able to recover the OEM back up camera function using the AX-DSP-CH5 AXXESS METRA T harness. I used the T harness between the vehicle 52 Pins connector and CTUJP01 connector, identified the cable associated with the camera functions ( Camera signal, Camera Return) on the T Harness/52 Pins, connect these two cables to composite RCA video cable.
4. I am stuck on the 9 Amplified Speakers w/Subwoofer.
The 9 Amplified Speakers w/ Subwoofer system is working fine with the OEM radio.
- When the OEM radio I unplugged from the vehicle 52 pins connector, the dashboard displayed " Audio Off", and turn back on when the OEM radio is plugged back into the 52 pins.
- When the OEM Radio is unplugged from the vehicle 52 pins conector, and the aftermarket radio is plugged into the vehicle 52pins, the dashboard still displayed "Audio Off", with no sound.
- I was only able to make the aftermarket radio produce sound thru the speakers when the OEM radio is unplugged and the aftermarket radio is plugged into the 52 pins, while the vehicle is on or running. Even in this situation, the dashboard still displayed "Audio Off", but the aftermarket radio produced, (not so outstanding) sound thru the speakers.
5. Any Help?
Discussion Starter #3
check this thread
Thanks
1. The unit i have is a universal unit, not specific to jeep renegade, the manufacturer did not have a specific CANBUS/harness integration. In addition they were plainly useless for any help. They still have not reply to my last email.
2. The Connets2 JP01 infotainment harness is only for non amplifier system. One tech told me that there is a software solution., another told me no way.
3. Will keep an eye on the thread aforementioned.
Thanks
Ask the seller if you can return the unit. There are Android units that are specific to the Renegade and include CANBUS integration. Some are now designed to work with the factory amp. These are drop-in units, 10 minute install. No additional parts needed.
1 - 4 of 4 Posts
