Yes, the radio is gone 😞. So I’m not able to purchase another used 6.5”and splice the wires? I was hoping it would be plug and play ...
From what I understand, and I may be wrong, it is not plug and play. Even if you get the exact same radio, it will need to be "married" to your vehicle, yes, that means a trip to the dealer. My 2017 Latitude radio came with a "code" card in my Owners Manual package. That code is vital in marrying the unit to the vehicle. Supposedly, without that code, the dealer can do nothing. And the dealer will also need the VIN of the radios donor vehicle as that comes into play also. This is the most dealer dependent vehicle I have ever owned.
In addition, if the dirtbag that stole your radio simply cut all the wires, odds are high you have blown fuses. This vehicle has 3 fuse panels, one under the hood, one buried under the dash (that requires panels to be removed to access as there is no access cover, genius move there, Jeep) and one in the cargo area, again, buried behind panels. It would be wise to check all 3 panels while troubleshooting.
Hopefully those that have more precise knowledge will chime in if I am misleading you anywhere.
Mud Pie Rant Time -
I started driving in 1976, most likely years before most of you were born. This Renegade is the most unfriendly user-serviceable vehicle I have
ever owned. Just putting in a "wrong" set of replacement light bulbs can make this vehicle crap itself and turn in tiny circles. Light bulbs. And they
purposely make it harder and harder for owners to work on their own vehicles. At one time owners could use an OBD tool or something similar to diagnose issues. Well, Jeep took care of that !! They installed a SGW (Security Gateway)
behind the radio to prevent owners from easily working on their own vehicle. Oh, rest assured the dealer doesn't need the SGW key... "A lot of vehicles are like this" provides no comfort.
The only thing I have done, and will ever do, to this vehicle is gently put a coffee cup in the cup holder. Everything else is just a roll of the dice.
Mud Pie Rant over, time for coffee.
