I posted about this in an existing thread but figured I'd give it its own in case others run into the same problem.
My Latitude has the uConnect 5.0, and for the most part everything works great. However it's acting strangely with regard to text messaging on my phone (Motorola Droid Turbo, Android 5.1 Lollipop, Verizon)
When I initially paired the phone, the uConnect messaging function worked perfectly. It would read incoming texts, and I could use voice commands to reply using one of the canned responses. It worked really well. However, I found later that when I got in the Jeep and the phone connected, the messaging button on the screen was grayed out. When I pressed it, a message came up that said "Texting is not supported on this phone."
So I deleted the device and re-paired, and texting started working again, until the phone was disconnected and reconnected, and then went back to unsupported.
So obviously texting IS supported, if it works once there's no reason for it to quit working. I saw it work, I used it!
I had a chat session with Jeep Customer Help and here's what I got:
Has anyone else run into similar weirdness?
This makes no sense to me. The functionality is there. I could use it if I wanted to re-pair my phone every time I get in the car.Delores: I am showing on the http://www.driveuconnect.com website that the only software that is 100% compatible with your Motorola Droid turbo phone is 4.4.4 you have a software version of 5.1.
Delores: If your phone is not 100% compatible with the 5.0 radio then some features will work and some will not.
Christopher Scott: Understood, but why would it work perfectly when the phone is first paired, then stop working when disconnected and reconnected. Obviously the feature has support if it works initially
Delores: because the software is not 100% compatible if you go to our website http://www.driveuconnect.com and view that site for pairing your phone when you click on your phone it will show the software that is compatible yours is not and so this is why it is doing what it is doing. Sometimes it will work and sometimes it won't if you had the droid turbo with the software 4.4.4 then it would not do thata.
Delores: You may keep checking that website for when they update the software to the 5.1 which you have on your phone. Then it would function at 100% capacity.
