1 - 19 of 19 Posts
2015 Trailhawk
Some members have reported problems with the computers that require a trip to a dealer to correct after running their battery too low. Waiting until you have starting problems to replace the battery is too late. It needs to be done proactively on our vehicles. I think 4 years is a good recommendation. You are on borrowed time in my opinion.
Appeciate the comments. Vehicle has only 20K miles on it and used in sunny FL. Found an Odyssey battery for $300 which I may order. Part of me says to wait until original dies, but don't want wife stuck someplace with a dead battery. Might mention this Renegade has been totally trouble free from day 0ne. Much more reliable than any other Jeep we have owned.
2015 Trailhawk
I was an early adapter of the Renegade. Up until I owned this Renegade and started reading reports of problems caused by dead batteries, I always ran my vehicle batteries until they would barely start the engine. I will not do that now.
2015 Renegade Latitude 2.4
Both extremes of hot and cold temperatures are hard on engine components. That and the age would make me opt for a change as you are about at the time for it to give up the ghost. It will be fine until it isn't and then you're in a bind. That battery and that Renegade will not give you any notice. The yellow top Optima battery has decent reviews but I'd just go with a name brand and not a discount battery.
During one of my oil changes at the dealer (when I bought mine, I got one of those packages, 3 oil changes, 3 tire rotations, 27 point inspection for 179 that I keep renewing), the report came back and had the battery as "fair". I left the dealership and went straight to NTB and had a new battery installed. Not worth the risk in getting "as much as you can" out of a simple battery.
My boss says I'm wasting money replacing a battery that isn't dead yet. I disagree. Sure, in the days of yore you could wait until the battery was flat then have your friends push start or jump start you for a few days, but in these heavily computerized vehicles, that's a no go. Batteries nowadays do a lot more than light your headlights and engage your starter solenoid....
2017 Renegade Latitude 4x4, 2.4 ltr
Yeah, I have a 2017 latitude with original battery and it's still cold where I live. I noticed it was turning over a little slow the last start. Also, I started down the road out of my driveway and it would barely accelerate. Pushing down the gas peddle and it would just bog. No trouble light. So I creeped back to my driveway and shut it off. Waited a minutes and started it back up and everything was fine.
So I'm thinking I need a new battery too.
3 years: Normal.
4-5 years: Good going.
\> 5 years: failure, just when you don't need it, likely.
We just replaced ours it was 5 years old but testing showed it was still good and had 590 CCA so not much degradation. The Battery said 600 CCA on the top. I was impressed but with us going on vacations and stuff I felt it was time to replace it just for general purposes !!
I've changed many batteries in many vehicles thus far in life. But with all the talk of how sensitive the electronics are on the Renegades, I am little concerned.
Is there any special procedure or something to be careful with when changing the battery?
Thanks
Not as far as I can see. My 2020 USB Service Manual just says to disconnect the negative post of the battery when doing electrical work. After first unplugging the Intelligent Battery Sensor first, if you've got that (the red thing on top of my battery):
Motor vehicle Vehicle Automotive design Automotive fuel system Car
After that, the battery obviously isn't grounded any more; there's no electrical circuit; and removing the positive post is trivial.
Nothing special in there about connecting the battery back up.
With some vehicles (like our 2009 VW Mk5's), there's some simple adaptation that has to be done when the battery is disconnected, with the power windows and the power steering. But I don't see anything like that here...
Well I planned to get a new battery this Saturday. Went out to start the car this afternoon and lights going off everywhere and not enough juice to turn over the starter. So I will definitely be replacing the battery this Saturday.
I’m in the same position, my 2017 a little lag when starting so I’m replacing it this week at Mavis. Putting in a 24 month Exide battery.
I put in a new battery and everything was fine. To my surprise, the radio still had all the stations I saved and all the car settings were still saved along with the blue tooth devices.
1 - 19 of 19 Posts
