Like the title says. Literally right before I come to a complete stop, my rig bucks or jumps once then stops moving. Disabled hill assist and it does it on all levels of surfaces. Anyone have a similar problem?
I noticed a similar sensation in a Cherokee I rented last week, but that was the engine shutting down as I came to a stop. Disabling the auto-stop feature took care of that. Not sure if you have that or not.
Mine does the same thing, it's when it's shifting back into first.
I've had nothing but problems be when it comes to going into and coming out of second gear.
Mine is the 9 speed trans tho, so that might be the difference.
Hello Snooks130,
We are certainly sorry to hear of your recent concern. Have you considered addressing this with your Jeep dealer? If not, we would kindly recommend doing so as they are in the best position to assist you. If you decide to go this route and would like additional assistance from our end, you can reach out to us via private message.
Laura
JeepCares
The 9 speed auto Renegade usually starts in 2nd gear in Snow Mode. They will not shift into first gear until a full stop. If there is any motion (rolling stop) it will stay in 2nd gear and shift upwards from there.
I just purchased this on Black Friday! I noticed at highway speeds of 65 and up it stays in 7th gear unless we shift manually to 8th. For 9th gear to work you have to be going fast. Shift it manually works but it won’t shift into 8th on its own? Took it to a dealer and they told us the...
Recently purchased a used 2015 latitude 2.4L with about 80,000 miles on it. Owned a 2005 Liberty before and sealed transmission is something new to me. I called my local Jeep dealership about doing a flush and they stated that it won’t need one for the life of the vehicle. Is this true? I find...
I just bought a 2018 Renegade. So far everything is great other than a strange transmission vibration at about 32 miles per hour. I searched the web and found others having this same problems all the way back to 2015. I read that turning off the traction control eliminates the problem and...
Seeming to have an issue sometimes where the car will seem to lag then jerk into gear. Seems to happen more when I’m coasting. Any ideas? Hoping nothing too serious. I love This car!
Hi all,
2015 Jeep Renegade Trailhawk.
Was away for 2 months and when I returned home, the vehicle won't turn over and I am getting multiple warning lights (prior to leaving - no issues, worked fine).
I was able to start it with a portable battery charger and have let it run for 30min...
