1 - 7 of 7 Posts
Is 2017 renagade is not on the list
It is if it is the 2.4L engine. If you don't have the 2.4 then yes, it doesn't apply to yours. What engine do you have and how much oil are you adding and at what interval? If it is the turbo engine, turbo engines will consume some oil since they use the oil as a bearing in the turbo generally. With turbo cars I've owned in the past I've usually expected to vanish about 0.5-1qt of oil every 3500 miles or so.
1 - 7 of 7 Posts
