My husband and I are both very experienced manual drivers. They are charging us upwards of $2400. The only reason we took it to the dealership is because my husband broke down on the side of the road and had no idea what happened. There hadn't been any grinding of softness in the clutch prior. It just quit moving. If there is a next time, we will take it to a reputable mechanic. We just found out our dealership has never replaced a clutch in a 2018 Renegade, and they are a Jeep dealership. Go figure!It really doesn't matter what percent of your driving is highway or not. The question is if you did anything that makes clutches unhappy, and how much of them you did. The clutch in the jeep is not a robust unit, and does not tolerate a lot of abuse.
11.5 hours seems a bit on the high side, but it's not a cheap job. Repair pal says $706 for parts and $900-1100 for labor. I know the people who have had it happen to them here and posted were getting bills of about $2k form the dealer, which jibes with repair pal as that usually shows book rate for an independent shop not quite as pricey as a dealer.
Thanks so much for all this information. He was on the expressway in traffic, at a near stop, smelled burning and when he went to go the Jeep wouldn't move. Unfortunately our dealership do not know what the are doing so they replaced the clutch, bearing, they broke the flywheel, then the broke the cable. It's been almost a month and they still have our JeepSounds more like a failed slave cylinder - failing clutches either won't release or slip. Failing slave cylinders are very common since they all went to designs that are internal and concentric with the input shaft. It's in there with the dust from the clutch plate which is very abrasive, and if it gets into the seals it can destroy them quickly. It is not just an FCA issue.
Well if he smelled burning it could well have been the clutch - it is hard to diagnose without being there. Perhaps the dual-mass flywheel failed first, causing the clutch to slip. Usually a clutch disk will not fail suddenly, it will begin to slip under load first.Thanks so much for all this information. He was on the expressway in traffic, at a near stop, smelled burning and when he went to go the Jeep wouldn't move. Unfortunately our dealership do not know what the are doing so they replaced the clutch, bearing, they broke the flywheel, then the broke the cable. It's been almost a month and they still have our Jeep
I believed the first part.My husband and I are both very experienced manual drivers. We just found out our dealership has never replaced a clutch in a 2018 Renegade, and they are a Jeep dealership. Go figure!
The second part is believable. I wouldn't be surprised to hear that my dealership never replaced a renegade clutch as they don't get manuals into inventory because most people don't want them, and they aren't really keen on doing factory orders for people. So if they are doing them, it's because someone shifted to them after purchasing someplace else.I believed the first part.
It's not just FCA, those slave cylinders are a terrible idea.And as Fiat power said, yeah there have been a lot of slave cylinders going on MT renegades in addition to the clutch material failing.
... Surprised they admitted to breaking parts, at least they are being honest even if they dont know what they are doing. ...
I remember pulling the transaxle on my Fiat 128 - I rigged a couple of 2x4s and a pulley over the top, and hung the rope down below. I could lift the transaxle from below without much problem, but one of those alignment tubes had got deformed and I couldn't get it to fully mate - the rope was handy after the 6th try or so!Wow thats sad. I used to change clutches on transverse engine vehicles in my driveway with a regular car jack and some boards and it usually took 6 hours or so. Surprised they admitted to breaking parts, at least they are being honest even if they dont know what they are doing. Still kinda scary, Id have an independent shop check it out once you get it back.
Raz, the Jeep Renegade is proving to be a very popular purchase in the UK.I wouldn't be surprised to hear that my dealership never replaced a renegade clutch as they don't get manuals into inventory because most people don't want them, and they aren't really keen on doing factory orders for people. So if they are doing them, it's because someone shifted to them after purchasing someplace else.
