1 - 13 of 13 Posts
Did anybody have this sunroof delievered yet? If so, how is it in everyday use?
I ordered my Trailhawk with it, should be arriving in the first week of June.
· Premium Member
@nuderobot
I'm curious, are there interior sliding cover for the command view panels? That can be closed by the occupants to block the sun.
TS
Yes, there is a electronic fabric material cover, which slides over both glass sections. The solid middle part under the 2 glass panels does not protrude down as far as in the MySky roof.
During my test drive in bright sunshine the cover blocked out almost all of the light.
Finally, my Trailhawk has been born in Melfi! Due to the vacation- closure of the Melfi plant until the end of August I'm expecting delivery end of September at earliest.
Until then, I'm getting a loan Renegade starting September 1.
@nuderobot
TS
I have seen pictures of that sunshade. It's one, power operated sunshade. It looks and operates just like the sunshade on the Fiat 500L glass sunroof. Now check out the dual sunshades on the Fiat 500X. Those are 2 manually operated roller sunshades. The rear passengers can cover up the sun theirselves on their back portion of the glass. Would be great if Jeep sold that glass roof in the USA and if it had that dual manual sunshade versus the single power one of the European only Command View roof.
I wonder if you could get an after market one installed. I couldn't find one with the my sky but my dealer found one that had everything but and then the dealer had a regular sunroof installed.
I've considered it, I've heard a lot of horror stories though about aftermarket sunroofs leaking and causing more problems than good.
1 - 13 of 13 Posts
