Called Jeep customer support...no resolution. Let's say you wanted to top off coolant a little, what are you supposed to do...flush the entire system to make sure you aren't mixing?!
If you know what coolant is in there, you can find out what's compatible. Call the coolant manufacturer's customer service hotline and ask them.
It gets confusing. I am coming from the VAG stable of vehicles and there were rules regarding miscibility in terms of coolant color. Neighboring colors are generally miscible, colors on the other side of the color wheel are not:
"Normal" coolant:
Green miscible with blue
Blue miscible with green
"Longline Coolant"
orange, miscible with red
"Improved Longline coolant:
Red disciple with orange
Purple, mix only with purple
Please understand these were the rules regarding coolants for VW/Audi/Porsche vehicles and those rules may not apply to the brands. Sadly you cannot rely on going just by color when deciding what's miscible.
By the way, you cannot really trust your eyes when judging the color of coolant. I myself have seen purple count that I could have sworn was orange.
With coolants there are many different types: Organic acid additive, Hybrid Organic acid additive, coolant with silica, low siclia and silica-free coolan, longlife coolant. Mixing different kinds can result in the worst case scenario gelling of the coolant and damage to the cooling system.
When in doubt about miscibility, don't mix without first ensuring compatibility. Always flush the cooling system thoroughly when switching from one type coolant to another. I switched my Audi from the conventional blue type to the orange Dexcool type of longline coolant without any problems after one year of ownership.
Zerex Compatibility Chart (PDF)
