1 - 10 of 10 Posts
Hi
When I first got my Renegade Ltd the DAB radio worked perfectly. Now it comes on intemitantly which makes it unusable .As anyone had similar issues or know how to sort this?
Thanks
Previous topics on the DAB radio all say the same thing.
DAB is intermittent and unreliable due to many different conditions like Hills, Mountains (yes we have them in Scotland). I too suffer the same effects in the Capital of the UK (not London but up beyond that wall :p:LOL:)
No, seriously, DAB seems to break up just at the best part of a song or a programme. Switch over to FM and hope for the best. Better still, use Spotify and listen to your downloaded sounds (y)(y)(y)
Discussion Starter #3
Since I had my battery changed it has been working better. I rang the dealership and they said faulty Ariel base is common and they have a backlog of orders to replace them
Please update the forum once you get a new aerial.
It will be intersting to compare the results.
Try the Virgin radio DAB channel for some brilliant sounds overthe decades. I found it quite reliable as opposed to the Absolute channels.
(y)(y)(y)
will change battery fix this issue? or you will have to replace the aerial base? Is it possible to order the unit and install on your own? Thanks.
From what I recall on a previous topic your aerial is glued on with double sided tape with the wiring inside it. Replacing it is a straightforward job.
thanks, is it possible to read that post? Are we sure there is no screw underneath it and it can simply remove by force?
I can confirm that DAB reception gets progressively worse over time with these aerial bases. Except for 2 blackspots of around 50 metres in our town, DAB reception used to be very good everywhere. Now it's unuseable except in some areas of high/clear ground and then it's intermittent.
In our Alfa Mito, reception seems to be fine still.
Are these bases only available through dealers?
1 - 10 of 10 Posts
