I finally got to fully test out 5 aftermarket dash speakers along with the stock pieces. For reference here are the speakers tested and their impedance (rated/measured):
4ohm / 3.5ohm - Stock
4ohm / 3.5ohm - Kicker 44KSC3504
4ohm / 3.1ohm - Polk DB351
4ohm / 3.1ohm - Hertz DCX87.3
3ohm / 2.4ohm - Infinity REF-3022cfx
3ohm / 2.4ohm - JBL GTO329
All speakers fit in the factory locations but the JBL's would need trimming on the frame so the grill will secure. Also the Polk tweeter extends significantly more than the others and makes contact with the grill but it is still able to snap closed.
I also put each speaker through a 20Hz - 20kHz sweep and recorded the SPL. This was done with the fade/balance set to 100% drivers front and volume set at 25. I still had the door 6x9 and Kicker 6.75" sub connected. Interestingly the 6x9 begins to roll off at about 160Hz above which the 3.5" begins to overpower it. There is also a distinctive drop at 500Hz and 2500Hz which must be in the processor because it was exhibited by each speaker.
Maximum SPL from each speaker was:
75.66 db - Hertz
75.17 db - JBL
74.65 db - Infinity
73.50 db - Polk
73.20 db - Stock
70.84 db - Kicker
While these are peak levels it was obvious that the Kickers were less efficient because while more detailed than the stock speakers they were not any louder. By comparison all other speakers were noticeably louder than the Kickers.
I'm by no means an expert but to my ears the Polk had the most "subdued" highs while the Hertz and Infinity were "bright". This is mostly due to the silk tweeter on the Polk vs Composite on the others. I did find the sound from the Infinity more "hollow" than the others and more fatiguing. The JBL struck a nice balance between the Polk and Hertz. Surprisingly after listening for a couple hours the Hertz sounded the best on Satellite Radio but a little harsh on HD Radio. The Polk sounded better on the HD Radio but a little muddy on the Satellite. The JBL struck a good balance between them. I'm going to keep auditioning this weekend but at this point it's down to those 3.
Here is an image of the Polk and Hertz graphs for reference.
75.66 db - Hertz
75.17 db - JBL
74.65 db - Infinity
73.50 db - Polk
73.20 db - Stock
70.84 db - Kicker
