Yes. Set them while they are cold.Yikes! I just assumed that the 42psi they're at was correct. I just looked and the door says 35psi … is that what I should lower them to?
Thank you! At least I only have 900 miles on the overinflated tiresYes. Set them while they are cold.
A couple of pounds either way to find the best ride is ok.Thank you! At least I only have 900 miles on the overinflated tires.
I wonder if this goes on with other dealerships? Surely Jeep can't be the only one this happens to. When I worked for Renault, I followed the pdi check sheet as per Renault's instructions. Not everyone was as thorough as I was.Its pretty sad that dealers get paid to do the PDI and they can't even check the tire pressures. Makes me wonder if they check anything else.
It happens at all dealerships it does not matter the brand. In every profession there are competent people that want to do a good job. There are also lazy bums that will do as little as possible to get paid.I wonder if this goes on with other dealerships? Surely Jeep can't be the only one this happens to. When I worked for Renault, I followed the pdi check sheet as per Renault's instructions. Not everyone was as thorough as I was.
Most dealerships will set tires at maximum sidewall pressure when placing vehicles on the lot to alleviate some tire flat spotting. After the sale, it is sales responsibility to make sure the vehicle heads back to the shop for final adjustments and then through wash for delivery.It happens at all dealerships it does not matter the brand. In every profession there are competent people that want to do a good job. There are also lazy bums that will do as little as possible to get paid.
Thank You! Great Employees are very hard to come by anymore!!I wonder if this goes on with other dealerships? Surely Jeep can't be the only one this happens to. When I worked for Renault, I followed the pdi check sheet as per Renault's instructions. Not everyone was as thorough as I was.
Yes, but my Challenger was an ordered car; it arrived at the dealer on a Tuesday, and I drove it home Wednesday. No lot storage for this car. All four tires were inflated to over 50 psi.. . .
This is taken directly from the PDI check off sheet:
Increase the tire pressure to maximum sidewall pressure if vehicle is going into lot storage.
That maybe so. But the car has a PDI before it gets handed to the customer. As part of the PDI, the tyres should be inspected and the tyre pressures set at the correct pressure. I know, as I PDI'd many Renaults.I find it interesting how people have no regard for what they will say on the internet when they are un-informed. They are SUPPOSED to set the tire PSI to maximum sidewall per the PDI process.. The delivery process, now that's another story.
Nobody here is talking about storage pressures.I find it interesting how people have no regard for what they will say on the internet when they are un-informed. They are SUPPOSED to set the tire PSI to maximum sidewall per the PDI process.. The delivery process, now that's another story.
But that's not when a PDI is done at any dealership. The PDI is done when the car gets dropped off the transport before it is put on the lot to be sold. A PDI is done, pretty much the same way, even if it is an ordered car that the customer is coming to get ASAP. AFTER the sale it is the sales departments responsibility to make sure the vehicle is ready to be handed to the customer. Service is not involved between the sale and delivery to the customer unless the sales department makes it so.Nobody here is talking about storage pressures.
That is irrelevant.
The delivery pressure should be correct.
The D means delivery not storage, as in a condition to drive on the road.
