As long as you have good reception (not in garage, tunnel, etc.) there should be no delay in radio. I have not had this problem and if it persists, take it to dealer. Good luck.
Did you or the dealer check to see if you had the latest software update?Hi,
Did you ever resolve this issue? I've got a brand new Ram 1500 with uConnect 8.4 and at random times I get a ~2 minute delay to touchscreen commands related to Sirius XM. Any commands to change channels, etc. get queued up and then all get delivered at once when whatever the logjam was gets cleared. It's only a temporary clearance, though, as the problem keeps happening over and over as you drive. I can change to FM, AM, etc. and those work fine, but when I go back to Sirius XM it will still be hung up. I've called SXM and they verified that my software and subscriptions are current; they then suggested that the dealer perform a reset. I took it to the dealer and they reset everything but one day later the problem is back ...
Here's a video : https://youtu.be/zd7LhSbghsU
Any updates would be appreciated!
I have the same exact issue - any resolution?Did you or the dealer check to see if you had the latest software update?
You can check for updates here: http://www.driveuconnect.com/software-update/
