Hello
I have a 2015 1.6 diesel Renegade- UK model and the oil change light has came on and I can’t get it off. It’s been well documented and discussed on the forum that the fix by pumping gas pedal 3 times doesn’t work on uk models (and I have tried this but hasn’t worked.) I have a cheap diagnostic tool that won’t erase the fault, although it does read it as such. I am happy to purchase a new diagnostic tool but there are so many and I want to make sure that it will remove the oil change light on my Renny, so can anyone advise from personal experience . I don’t want to be spending hundreds of £ but if anyone has successfully used a reasonably priced diagnostic tool to get rid of the oil change light on a uk model, your advice will help a lot. I’m just wary of buying another that’s no more use than the one that I gave and from reading the forum, some people do appear to have used a diagnostic tool and successfully removed this fault.
Thanks in advance to anyone who can point me in the right direction and avoid me going to a dealer/ garage to get this fixed.
Cheers.
Cheers.
