1 - 2 of 2 Posts
Good evening.
Need an advice.
I have 2019 Jeep, and have some problems with diagnostic.
I have bought in internet MICROPOD 2 with Wi-TECH (V17.04.27). When, I found out that it is impossible to delete trouble codes, because of SGW module. I bought bypass wire and have received it today. But, when I connected it, I saw messages about the protection system. ANd I can't switch on the ignition and turn on diagnostic. Could anyone help me to solve this? What should I do to connect bypass? Where is the problem?
and MICROPOD 2 to delete all troublecodes?
Red Font Magenta Fashion accessory Event
Vehicle Automotive design Gadget Personal luxury car Font
Automotive lighting Automotive design Vehicle Gadget Motor vehicle
W E L C O M E ! ! !
... to the forum.
Looks like you unplugged the wrong module. The 12 +8 adapter that you received replaces the SGM while you are clearing the codes.
For example;
Unplug the two connectors going in to the SGM, those two connectors will plug in to the 12 +8 adapter and then you plug your scan tool in to the 12 + 8 adapter, effectively bypassing the SGM.
I have a 2020 Grand Cherokee and have used that 12 +8 adapter on several occasions and have never seen Vehicle Protection System error message.
What kind of scan tool are you using?
This should be the location of the Security Gateway Module for your Renegade. should be...
Automotive tire Motor vehicle Hood Vehicle Automotive design
1 - 2 of 2 Posts
