That's the incessant sound of the seatbelt reminder chime. Is there a way to disable it? It's driving me nuts!
The other way is to drive out of your garage a bit slower and the DingDing Ding will not appear without Tricks or so ... its even better for the cold engine not to performe a Jumpstart every morning ... ok your wife awakes you every morning with a kick in the ass too ... but why should the Renny treated same way as you?Thank you for the replies. Don't worry I wear my seatbelt 99% of the time. There's just some instances I don't wear it like when I have to go up and down seven levels in the parking garage. And then have to jump out and use a key card and jump back in the car and it's just a pain in the butt.
I tried this and it didn't work. I just might get one of these.I'm not gonna get dragged into a debate as to whether seatbelts should always be worn or not, but this is what previous Jeep models had in their owners manuals - not sure if the Renegade has something similar:
1. Turn the ignition switch to the OFF position, and buckle the driver's seat belt.
2. Turn the ignition key to the ACCESSORY/RUN position (engine does not need to be running), and wait for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle and then re-buckle the driver's seat belt at least three times within 10 seconds, ending with the seat belt buckled.
4. Turn the ignition key to the OFF position. A single chime will sound to signify that you have successfully completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated by repeating this procedure.
NOTE:
Although the Enhanced Warning System (BeltAlert) has been deactivated, the Seat Belt Warning Light will continue to illuminate while the driver's seat belt remains unfastened."
This is from a 2015 CherokeeBeltAlert
can be enabled or disabled by your authorized
dealer or by following these steps:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. Chrysler Group LLC does not recommend
deactivating BeltAlert.
buckle the driver’s seat belt.
2. Turn the ignition key to the ACC/ON position (do not
start the engine), and wait for the Seat Belt Reminder
Light to turn off.
and then re-buckle the driver’s seat belt at least three
buckled.
BeltAlert can be reactivated by repeating this procedure.
NOTE: Although BeltAlert has been deactivated, the
Seat Belt Reminder Light will continue to illuminate
while the driver’s seat belt remains unfastened.
The inconvenience of having to unlatch the buckle vs. someone pulling out of a parking spot without looking and possibly slamming into you and causing injury.Thank you for the replies. Don't worry I wear my seatbelt 99% of the time. There's just some instances I don't wear it like when I have to go up and down seven levels in the parking garage. And then have to jump out and use a key card and jump back in the car and it's just a pain in the butt.
I put a 52 oz cup in the passenger seat all the time and it has never once activated the alarm. Yours must be a lot more sensitive than mine or there is something wrong with the sensor.
