Anyone know bulb number looks like 194 but has different number than cargo lights that are 194s.
Not sure if they are Canbus, package didn't say. I did try some other LED's first and they didn't work and stayed dimly lit when off. These are the most noticeable in the overhead lights by the rear view mirror, seem to be twice as bright, nice and white.Where they Canbus or regular leds. Are they a lot brighter? If they were the regular bulbs did you have that light dim on when they were off?
How about the exterior lights. Is the manual correct on them?Manual is wrong, bulb is 194. Just updated all interior bulbs to LED, they all were 194 (didn't do the vanity though, not sure about that bulb) I used Sylvania LEDriving premium white LED's. Work great, nice color, listed as a 6000K
I plan to replace the 2 interior map lights and the license plates bulb. Any tips getting the panels off? I don't want to break anything or rip the headliner. The panel for the map lights seem pretty tight. And the license piece, which side do I pry out from?Finally got around to replacing the bulbs. Replacing the map lights was a PITA. I ended up using these:
https://www.superbrightleds.com/mor...-led-tower-miniature-wedge-retrofit-car/1127/
The ones I got from diode dynamics were too thick and the resistors were in the way of everything. These fit perfectly. No dim lights or anything, but I did get a bulb out warning from the ones I put in the reverse light. I may try changing them around though, because the other bulbs I got for the DRL are not triggering the bulb out warning. So maybe one of the ones in the tailight are defective.
I read about how to remove the map light housing. What about the rear dome light housing?Manual is wrong, bulb is 194. Just updated all interior bulbs to LED, they all were 194 (didn't do the vanity though, not sure about that bulb) I used Sylvania LEDriving premium white LED's. Work great, nice color, listed as a 6000K
The rear is easy, was able to just use my fingers, pry panel from the driver's/left side.I read about how to remove the map light housing. What about the rear dome light housing?
http://www.jeeprenegadeforum.com/forum/57-interior/20785-map-light-covers-2.htmlThe rear is easy, was able to just use my fingers, pry panel from the driver's/left side.
Where you able to do the fronts yet? If so, any advice. I bought panel removal tools on amazon, hope they come in in time for this weekend.
