1 - 18 of 18 Posts
Hi. I have had an issue with my jeep renegade today. When I went to unlock the doors using the button on the inside after driving the locks would not unlock. I have had to open the drivers side window and manually unlock the drivers door with the key from the outside. All the other doors will not open. The boot will open and lock fine. The drivers door will lock fine with the key fob or the button on the inside but will only open using the key from outside. I have tried disconnecting the battery but no joy. Any ideas please? Thanks
When you say "unlock the doors using the button on the inside after driving the locks would not unlock." do you mean the BIG door-open lever on the drivers door?
I too have had this happen until I realised that on my drivers door arm-rest is a small button with a lock on it. Pressing that disengages ALL door locks.
Just the other day the same thing happened to me in another car. The driver told me to simply pull the door release latch/lever twice. Apparantly it's a safety feature on BMWs. Could this also be the same feature on the Renegade? o_O:unsure:
Please try it out and let me know (y)
Discussion Starter #3
Hi. No I mean the small button with the lock on it. I have tried pulling on the lever a few times but no joy 😩
Will the passenger door lock button unlock the doors?
Does the passenger door unlock when you pull the inside door handle?
Check fuses, probably the ones in the Body Control Module (BCM), this fuse box under the dash.
The Drivers Door Control Module could be faulty.
(How it works: You request to unlock the doors from the drivers side unlock switch (the switch assembly is the Door Control Module). The Door Control Module tells the BCM what you want it to do and the BCM unlocks the doors. If you press the passenger door unlock switch, the passenger Door Control Module makes a request to the drivers side Door Control Module, which in turn tells the BCM what you want it to do and the BCM unlocks the doors.) (It is the same process when you want to roll down a window from any of the doors. All request are made to the drivers side Door Control Module which tells the BCM what it is you want to do.)
Might require a Software update for the BCM.
10 minutes ago when locking my car I momentarily had a flash of genius and remembered your post.
I have a habit of double pressing the lock on my key fob and it stems from 2 other cars that I had. This is something I do automatically with the Jeep and you can clearly hear the locks activating in a different manner on the second press of the fob.
Guys feel free to tell me if I'm wrong on this: A single click locks the doors but a second click activates the "Dead Lock".
The dead lock works on the principle that if your car is broken into eg. Smashed window that the crook cannot open the doors using the handles. It's a security feature that requires the insertion of the key into the lock.
@Jade, is it possible that you accidently activated the dead locks? :unsure:
Hmmm I just re-read your post and this won't be the issue as your doors are still locked. Sorry but I think IDMOR in the above post is clearly on the right track. (pardon the pun) :D
Discussion Starter #6
Thank you for your reply. I have had the breakdown people out to look at it for me as I couldn’t get into the petrol cap to put fuel in and was running on fumes so couldn’t get the garage 😩
They have sorted this for me, but the doors are stuck on dead lock he said. He couldn’t get it off and said he thinks it needs a computer reset so i have just booked it in with Jeep on Friday.
Thanks for your help guys it’s really appreciated. I’ll update with the solution when it’s fixed 🤞🏻
Hi Jade - I was wondering if you have any feedback on the door locking issue? I've been having exactly the same problem. I've been to the dealer and they can't solve it.
Hi Sue,
We are certainly concerned to see this happening with your locks. If you'd like additional assistance while you are working with your dealer, send us a PM so that we can look into this further for you.
Kathryn
JeepCares
Hi Sue,
Kathryn
JeepCares
Hi Kathryn - thanks for your message!
I’ve actually taken this up with FCA Head Office here as for me this is a huge safety and security concern. I’ll happily let you know when I hear back from them 😊
Glad to hear that you've been able to reach out to someone, Sue! The customer service in your region will be in the best position to assist you from here. Thank you for keeping us posted!
Kathryn
JeepCares
Discussion Starter #15
H
I took it to the dealer and it needs a new BCU (body control unit) 🙈they tried an update but no joy. It was meant to be fixed yesterday but they sent the wrong part over from Italy so I’m stuck another week. This will now be 4 weeks of having my car stuck as a 1 seater. Good luck and get them to look at the BCU
Discussion Starter #16
Hi just thought I’d update. My car is fixed 😊 after 5 weeks of the doors being stuck on deadlock they finally open. The new BCU has done the trick. Apparently it was a nightmare for the mechanics trying to access as it is located on the passenger side and so they had to get the door open to be able to replace 🙈 but so far so good so 🤞🏻Thank you for the advice 😊
Thanks for the update.
I was laughing to myself when reading, because the BCM is on the drivers side (here in the US). lol
1 - 18 of 18 Posts
