Hey everyone, hoping one of you can help me out...
My wife's 2016 Trailhawk is currently sitting in the driveway dead. She used remote start to warm it up and she looked out the window to make sure it started, but as soon as she saw the side-view mirror lights blink she assumed it started. She didn't hear if the engine actually started or not. We came out about 10 minutes later and the engine was off but the headlights were on (normally if you leave it running it'll shut off after 10-15? minutes and the lights turn off too). When I got into the car, the instrument cluster showed "Remote engine start active" or whatever, so it seemed like it thought the engine was still running. I tried pushing the ignition button and it did nothing. Absolutely nothing. If I pushed the brake I was able to shift it into Reverse, Neutral, Drive (which was odd considering it was still in 'remote start').
Anyways, after realizing I was getting the Jeep equivalent of the blue screen of death, I pulled the negative battery terminal, left it for about 30 seconds and reconnected. Now I get nothing. When I open the door the cabin lights come on normally, but the instrument panel is black, and I have the red BRAKE light blinking. Again, the ignition button doesn't do anything. The radio will come on if I push the power button. Otherwise it's like the battery is completely dead (battery was replaced ~4 months ago, was testing at ~12.4 V with all this happening so I don't think it's the battery). I tried disconnecting and leaving it for ~45 minutes and still nothing. Checked all fuses that made any sense and all looked good.
I connected an older Actron code reader to the OBD port and it obviously had connection problems, but when I went to the erase code function, it was telling me "engine is running, turn key on, engine off."
Could this be a bad ignition switch?
Thanks in advance!!!
Matt
Matt
