I've called 2 dealerships. They tell me only a part number, no dimensions listed.The 2.4 engine is made in the USA, they may not be the same. Your dealer should be able to tell
you what size you need.
Clifton
Fumoto lists the F-106 Qwik Valve as compatible with the 2.4 L and the 1.4 T. It has a 14 mm thread, 1.5 mm pitch, cost ca $24.Can't find the dimensions for the oil drain plug and I want to order an EZ drain plug. Do you think the one that fits the Fiat 500 would work? I have the Latitude 2.4 engine.
Thanks!
Go to the parts department at the dealer. With a little luck they have a drain plug in stock and you can take a look and take a measurement. If you feel cheap doing that, just buy a drain plug. It costs about $2.50.I've called 2 dealerships. They tell me only a part number, no dimensions listed.
