Mine does have a tendency to turn itself off - and the only way to turn it back on is to turn off the ignition, and then re-start the car.
Seems to happen most when you have to start and then stop the car in a short period of time - like when moving it around on the drive prior to going out for the day... the first time you start, it's ok, but if you switch the engine off after a couple of minutes, when you re-start, the FCW light comes on, and the settings on the Audio system are blanked out, so you can't switch it on manually.
