1 - 1 of 1 Posts
2017 Sport 1.4L Turbo 6MT 4WD
Motor vehicle Automotive tire Automotive design Automotive fuel system Gas
Also added my Forge turbo blanket. I had the blanket for a while but was waiting to replace the wastegate actuator so I wouldn't have to re-install it a second time. Everything was easy enough (for me) to install. Only real issue is the aftermarket intake tube is thick enough that I couldn't get the clamp as close to the turbo as I would have liked. But it is on the right side of the ridge on the turbo intake so it is doing its job.
I am not sure if I needed to but I had the battery disconnected all night before adding these this morning so the computer(s) would reset. Then I drove around a while after the install to get the trims lined up. Was running great!
1 - 1 of 1 Posts
