Raise the beam.
You do have the headlight throw adjusted to highest on the knob next to the headlamp switch don't you?...
Perhaps you should forward your findings to Jeep, and also let them know that they are incorrect on page 24/25 on the manual?Well Ted, I think you better check your fuse panel. If you don't have a burnt fuse you will shortly as I think you have a random short between the seat and the steering wheel.
The only adjustor is for the dash lights and high/low beams.
.:ReneBlueWave:
Do European cars have headlight level adjusters? I had a buddy who could raise and lower his headlights from inside the vehicle. It wasn't a Jeep though. It worked kind of the same way the auto leveling headlights work, except he could do it manually using a knob on the dash. Maybe that's a Euro thing?Perhaps you should forward your findings to Jeep, and also let them know that they are incorrect on page 24/25 on the manual?
Actually, thinking about it,
The only adjustor (sic) is for the dash lights and high/low beams
You're not using that to switch between 'low' and 'high' beams are you? >>
:laugh::laugh:
Every car I have owned for about 20 years has had a wheel switch to alter the headlamp height aim. on my renegade it is beside the dash light adjuster.Do European cars have headlight level adjusters? I had a buddy who could raise and lower his headlights from inside the vehicle. It wasn't a Jeep though. It worked kind of the same way the auto leveling headlights work, except he could do it manually using a knob on the dash. Maybe that's a Euro thing?
I thought that's what I remember. Here in the states we don't have that feature. It would be really cool to have.Every car I have owned for about 20 years has had a wheel switch to alter the headlamp height aim. on my renegade it is beside the dash light adjuster.
To be honest I have only used it when towing my caravan.I thought that's what I remember. Here in the states we don't have that feature. It would be really cool to have.
Well, yes, the leveler is supposed to be used only to decrease headlight range when the car is heavy in the butt due to passengers or towing. You decrease range until the "normal" range is achieved. That's why it's called a headlight "leveler. If set up properly, you only can decrease headlight range with the leveler. One could abuse the leveler by improperly setting up the basic headlight setting via the housing adjustment screws.To be honest I have only used it when towing my caravan.
