1 - 14 of 14 Posts
my 1.4 renegade rear washer has ended up just dribbling out of the rear jet, and the front has lost pressure,any ideas.
can the pump get blocked as you can hear the motor working .
where is the pump located please
much obliged
much obliged
happened to my trailhawk last month, seems to be a common problem--- probably the pump for the rear window--- pumps are located on the bottom of the water tank not easy to get to, i am going to let the dealer fix mine
W E L C O M E ! ! !
... to the forum.
Check for leaks as it runs inside under the (on UK side) passenger door trims.
Otherwise as jeff1 says it could be the pump motor.
It's a single unit for front and back with a check valve. Spins one way for front and the other for rear.
much obliged
thanks everyone i think i will change the pump
and enjoy the forum!
thanks for info
did not know single two way pump. front one works fine , nothing for the rear
[/QUOTE]
Get your local garage to stick an air pipe onto the pump. Often the algae build up inside the water bottle can clog the impellor (think a small propellor) within the pump.
A blast of air can often release the algae/debris/dirt.
1 - 14 of 14 Posts
