I have, everything is routed correctly - I must have messed up the physical connection somewhere. I'm also trying to use the metal brackets holding the lights as grounds, that may be an issue.Check the wiring diagram.
Hey Sun-RunnerWow. This forum really isn't very helpful. Either no one checks it or no one knows anything lol.
...For anyone who needs this info, I found this page from Mopar where you can find any wiring diagram for your vehicle:...
Mopar Connection Repair Kit
connectors.dcctools.com
Going off the only resource I had - the diagram from the website I posted. It lists the wire color, and the position on the diagram looked like a match for the actual wire in my engine.And how certain are you that you’ve isolated the correct high beam wire? It doesn’t sound like you had complete confidence in saying that.
I am going off the diagram/picture here to isolate the high beam wire. I'm following the Hellas' instructions, which show splicing the wire from the relay into the high beam wire. On my actual headlamp wiring, there was indeed a green/black wire positioned where the picture shows. Hellas came packaged with all wires/relay and a switch which I'm not using. I'm just using the high beam to trigger the relay to power the Hellas (or at least trying to).Hey Sun-Runner
There were no wiring diagrams at this link, just connector configurations. I hope you aren't relying on just that to try and wire in anything. If you are just wiring in extra lights to come on when you switch to high beam, have you taken into account the amperage increase? You could be overloading the fuse and factory wire, unless you are just using the positive side to activate a relay to turn on the Hellas.
I've only just got home from the caravan and opened a beer but I know the answer.
Give me till tomorrow morning and I will give you a picture of the wire.
I had my mates mechanic identify the exact wire and I have a piece of insulating tape wrapped around it. It was needed so I can connect my Light Bar into my full beam switch.
Apologies for only getting around to reading the posts but family life and relaxation comes first of which I know you will understand.
Aghhhhh this is 3rd time the cat has jumped onto the keyboard.
The things that I have to put up with in order to give a timeous reply to a frustrated member.
Green and black is the live wire for full beam.
From experience, you don’t really want to go the fuse box direction anyways. Seems like the fuse box is prior to the switch, so tapping in there would just give you constant power.I was going to install led bar to my Renegade, so does anybody know if its possible to take high beam trigger somewhere else than directly from plug/wires going to headlight? Im pretty sure its possible to do much easier for example from fusebox but owners manual says nothing about high beam fuses. :O Car is 2021 EU version.
Click the red link. I missed it in Jeepatrons last postGive this a try— a wiring diagram for the headlights. Might be able to track it to somewhere else than the plug. I believe you have to open the link in google chrome for it to work though.
