1 - 9 of 9 Posts
This is my first post, sorry if I do it wrong.
I need to get my USB / Aux socket, but I am lost in how to?
Hope you know.
br
Karsten - Denmark 馃槈
You鈥檙e in luck. I鈥檓 trying to wire my CB directly into the cigarette lighter right next to the USB/AUX. I鈥檒l work on it and get back to you.
Happily, I got it figured out.
This process works for my American market Jeep, but I expect the process is very similar or exact for the Denmark models.
First, you need to remove the center console. You can follow a tutorial here.
Next, navigate to the passenger side footwell and go towards the area marked red.
2396348546
Next, remove the bolts marked red. Do the same on the other side in the drivers side footwell.
2396348547
You then need to unclip the unit from these latches on both sides.
2396348549
2396348551
Once that鈥檚 done, you can now start sliding the unit towards the rear of the car. It鈥檒l only move a few inches or so before the wires tug. So, you need to unplug them. I found it鈥檚 easiest to do so from the drivers side footwell. I had four for my car, but some may have less.
2396348550
After that, just take it out! You can unlatch the USB/AUX module from the plastic housing at this point.
Good luck on your project!
The guys have said above all that needs to be said.
Simply outstanding what a couple of pictures can show in comparison to a description. Thank you. 馃弳馃弳馃弳
1 - 9 of 9 Posts
