2.4 engine, 2017 latitude.
I remember seeing 2 coolant bleeder screws, but don't remember both. I found the one on the top of engine above the thermostat housing. I don't remember where the other one is at.
With engine cold, do you unscrew bleed screw with the reservoir cap on and under pressure or with the cap off?
OR
Is it it even necessary at all?
I have read that on pressurized systems if you rev the engine to 2000 RPMs for 15 seconds several times it will self bleed.
Thoughts?
Thanks
OR
Thoughts?
Thanks
