1 - 20 of 25 Posts
hello all i have been trying to figure out how to remove run from my instrument cluster i got the annoying speed warning off now i wanna change this any help would be great....i already checked in the options and saw nothing for the right side only for left and the middle :(:(:(:(
Speed warning setting is under Uconnect, security/safety.
RUN indicator on gauge cluster is under its configuration screen that you can navigate to using the steering controls.
you can change this with the command knobs left on the steering wheel ...
Engine running but not driving
press the up Arrow repeatidly for display options
then press ok then you can choose what will be displayed in the left middle and right corner ...
the dsplay options menü will not be available when you are driving ...
I only have those 4 options.... Upper left, center, gear display, and restore ??
. . . Same options as my Trailhawk. On my Dodge Challenger, I can change the display on the upper right, but not on the Renegade.
Reactions: Fatkatdadon84
· Premium Member
I dont think you can customize the upper right quadrant on the Reneagade like you can on the Cherokee and Grand Cherokee. I believe we are stuck with RUN:(
I tried what was recommended and still ended up with the same end result run can't be changed for some strange reason
Do you guys all have push button start? Could it have something to do with having that?
I have the option to change upper right and I don't have push button start.
Yes, mine has the push button start. Makes sense; FCA likely thinks that people with cars that do not have a turn key ignition won't know if the car is running or not. LOL :laugh:
I have the same issue. After reading all the posts, not having the upper right option must be caused by not having a key.
That´s not right ... i also have keyless entry and hae cheged the Display as described to Temperature not to show run ...
1 - 20 of 25 Posts
