Prerequisites
Oil filter wrench (or you can just use your hand, plenty of room)
12mm socket, or equivalent SAE
5.5 quarts of 0w-20 oil. I used M1 Advanced
Oil filter. I used Purolater L122222
Drain pan
Some kinda funnel. Don't make a mess.
Shop towels
Maybe some ramps? Can probably be done without ramps if you have long arms
Gloves
Steps
Drain pan
Shop towels
Gloves
Steps
- Get your gloves
- Warm up engine, but not crazy. It's hot oil , bro.
- Wait for your neighboors to make snide comment about Chrysler or American cars...
- Get the Renegade in the air. Be safe, please.
- Open hood and remove the oil cap. Don't remove it all the way, just crack it open. Don't want anything falling in.
- Loosen oil filter slightly to make sure it will even come undone.
- Position drain pan [incorrectly] and loosen the drain plug.
- Watch it drain.
- I usually pour a little bit of fresh oil at this point to help flush out the old stuff. Not too much though.
- Tighten drain bolt back up. Not too tight! Doesn't require much force, just snug and then a little more.
- Remove oil filter. It will be full of oil. Be sure to have drain pan under it.
- Let it drain a little bit from oil filter housing
- Use a little oil on the gasket of your new filter, then spin it on. Again, don't over tighten. I always install oil filters by hand.
- Pour in 5.5 qt of fresh oil
- Put oil cap back on
- Start engine
- Make sure no leaks...
