1 - 7 of 7 Posts
I know several members have changed their tail light and license plate bulbs for LEDs. Any tips on getting to those bulbs? I tried gaining access to the license bulbs, but I couldn't get the lenses/housings out -- I was pushing/sliding them to the side and then trying to pull down but they wouldn't budge.
On the license plate lights, I found that my assembly didn't match what was in the manual, and that it really was easiest pushing on the tab from the outside not the inside, the inside part has 2 tiny plastic hinges which are easy to break off (found out the hard way) but the outside edge has a metal tab which you can push in and pop out the assembly. Hope this helps.
Is there a way for either of you to show me this tab. Looking at the lens housings from the outside, I don't see a tab. Just the clear lens surrounded by a black trim piece. I can slide the whole housing to the left about an 1/8 - 1/4 of an inch and then try to pull down, but it doesn't budge. I didn't want to pull any harder and risk breaking tabs, etc.
I'll take a picture when I get home to show what I mean.
1 - 7 of 7 Posts
