1 - 4 of 4 Posts
Does anyone know how to remove the radiator fan? It's a simple snap on part but we can't see how to get it out of the space provided without removing major parts. There is not enough space between the engine and radiator. Has anyone removed one before and if so how?
[ame]https://youtu.be/hT-mK14pmUo?t=299[/ame]
I found this video on you tube. This might help you.
There are others so I suggest you watch a few of them so you'll have an idea.
It is simple procedure. You need to have some tools to do the job.
I hope this helps.
I just did this last week! I did step by step with the video and it was a pain but better than dropping two hundred plus dollars to have it put in.
Yes, perfect.
Today while I was reading some posts I saw one where an actual class action lawsuit was filed regarding this common problem. I hope it comes to a favorable resolution to us owners. I guess the litigation will be starting soon and hopefully those who spent so much money for the repair will be compensated fairly.
1 - 4 of 4 Posts
