How to replace battery
15395 Views 13 Replies 8 Participants Last post by  puddlesplasher
hey guys....my battery is 3yrs old and I want to get ready to replace before it fails....I was wondering if there is anything special about replacement....I have heard/read that if you wait till the battery fails you can have trans/computer problems.....any advice would be helpful....most new cars have a capacitor to hold a charge while changing the battery...is that true with our jeep....thanks for any advice...
1 - 14 of 14 Posts
Just remove neg line than pos line unbolt from tray put new one in. Bolt it down connect pos than neg your done!
Reactions: 3
Mrsig can you recommend a battery....my battery reads 12.2v with no load in morning and the load test is right on the line of being in red zone...the battery is 3yrs old don't want to take a chance with it....it's a group H-6 I think....is the Walmart platinum battery any good or is there something else I should be looking at...thanks for all your posts over the years...helped a lot
Just to provide a little more detail... (DYI and How-to)
It is a Group 48 (H6) battery.
There isn't a capacitor to hold a charge (your stereo shall retain their preset while the battery is disconnected (I don't know why, but it does)).
ENSURE that the ignition is off.
Remove the negative terminal by using the quick disconnect, move the battery cable out of the way.
Remove the fuse block cover from the top of the battery.
Remove the two (2) cross tip screws in the ‘Red’ retaining bar.
Remove the ‘Red’ retaining bar (clip) (be careful, don't break it), it should pull straight up.
Remove the positive terminal using a 10mm wrench to loosen the nut; lift the fuse block and the positive cable as a single unit.
Using a 13mm socket, remove the battery hold down retaining strap; lift it up and out of the way.
Lift the old battery from the battery tray.
Set the NEW Group 48 (H6) battery in the battery tray.
Pull the battery strap over the top of the battery and secure the 8mm nut using a 13mm socket.
*Set the fuse block and positive battery terminal onto the positive battery post.
Insert the ‘Red’ retaining bar/clip through the fuse block into the battery and secure it with the two cross tip screws.
Tighten the positive battery terminal using a 10mm wrench.
Replace/install the fuse block cover.
*Install the negative battery terminal, securing it by the quick disconnect.
* = I use anti-corrosion felt washers on my battery post before installing the battery terminals (optional/recommended).
Wal-Mart battery should be fine.
I am partial to Interstate, or Napa brand Batteries, they have always done me good.
I am currently using an Optima battery, Optima Yellow Top H6 Batteries 9048-148 (it is over kill).
Automotive battery Product Auto part Plastic
See less See more
Reactions: 2
I have been running Optima Yellow tops in my Jeeps for years. With lights & winch use I get about 5 to 6 years out of them.
Reactions: 2
T
That was my thought also. I have a winch, roof (Light bar), and Ditch lights on the Renegade. I wanted a solid battery.
I have been using the Optima Red Top batteries in my Hot Rod for years, Yellow Top my my off road vehicles.
Reactions: 1
T
Any pictures of your hot rod?
10
lol, do I have any pictures... I don't have these anymore. :( But I built all of them.
Except the R1 (Motor Cycle), I still have the R1, and the Ramcharger, WIP.
I am currently playing with a 2004 Mustang GT, WIP. Nothing worth posting yet.
Land vehicle Vehicle Car Muscle car Coupé
Land vehicle Vehicle Car Sports car Coupé
Land vehicle Vehicle Car Jeep Jeep cj
Land vehicle Vehicle Car Jeep Off-road vehicle
Vehicle Car Vintage car Machine
Land vehicle Vehicle Car Jeep Motor vehicle
Land vehicle Vehicle Car Bumper Off-roading
Land vehicle Vehicle Motorcycle Car Red
Land vehicle Vehicle Car Hood Mid-size car
Engine Vehicle Auto part Car Fuel line
1970 Plymouth GTX; 440, 4 speed. 11.6 second 1/4 mile car.
1986 Pontiac Fiero GT; 2.8 bored ans stroked to 3.1. 13.2 second 1/4 mile car.
1951 Willys MB38; 1965 Ford 289, C4 transmission. NOT a 1/4 mile Jeep.
1950 Willys CJ3A; 1970 Chevy 350 (350 HP), Turbo 350 transmission, T18 Transfer w/ twin sticks, Dana 30 front, Dana 44 rear 4.56 gearing. NOT a 1/4 mile Jeep, would pop a wheelie across the street. Would climb anything.
1977 Ramcharger; 440, 727 transmission, NP 203 transfer, Dana 44 front 9.25 rear 3.55 gears
2005 Yamaha YZF R1. Lots done. 10.4-ish 1/4 mile.
1998 Mustang GT (Crazy 8); 4.6 (597 HP, 611 lb-ft), T56 transmission, 8.8 rear 3.73 gears. The most I have done to a car. 12.2 1/4 mile car... at 156 mph, it is time to shift into 6th gear.
All have Red Top Optima's except the R1.
The GTX had 2 Red Top Optima's. lol
See less See more
Reactions: 2
Cool stuff Ed! I especially like the GTX, Fiero and Ramcharger. (y)
Reactions: 1
Man this was/is a PIA! I got a H6 at Walmart and they were on an Emergency work only order from store mgr? I got an EverStart Maxx H6.
Anyway they loaned me the sockets to swap it myself and I got about 90% done sheesh. Not enough extra cable lengt for their terminals ugh pain to get in and out. Got the new battery in and it won’t sit flush the Neg side sitting higher, wiggle and work and get the Neg side down enough to attach that. The kicker is not enough that the strap will reattach it’s almost 3” from reaching the bolt and acts like won’t pull any farther. It’s same size as the Mopar, I left as is and fool with it another day when it’s warmer.
Ce las vie.
Such is life, as a simple battery swap worked for all of us. 🤷‍♂️🤷‍♂️🤷‍♂️
Reactions: 2
I just changed out the OEM battery on my 2015 2.4L. Easy swap - 25-minute job. Got the Interstate battery from Costco. 730 CCA, 910 CA. I don't have a lot of extra electronics, so plenty for me.
Reactions: 1
Only when replacing the Jeep battery was I made aware of the different battery models. ie some have Positive on the left side and another model has them on the right side.
It's important to have the exact model so you don't have to worry about cables length being incorrect.
It reall is a simple, straight swap.
1 - 14 of 14 Posts
